Setting Device Information Notification Restrictions
You can restrict the Web browser from appending device information to the HTML request header.
Even when this restriction is enabled, the device information is displayed when communicating with addresses set as trusted servers.
Press [Function Settings] → [Web Access] → [Settings].
Press [Security].
4.
Select [On] for <Restrict Share Device Information> → press [OK].
The device information is only appended when processing requests for the addresses set in <Trusted Server Address>.
If you select [Off],The device information is appended when processing requests for all addresses.
If <Restrict Share Device Information> is set to 'On' and nothing is set in <Trusted Server Address>, device information is not appended when processing requests for any address.
» Web Access » Customizing Settings » Security Settings » Setting Device Information Notification Restrictions
08KY-18H
