Printing
This section explains the basic printing method using the printer driver.
Printing methods may differ depending on the application you are using. For details, see the instruction manuals provided with the application.
Select [Print] from the [File] menu of the application.
Select your printer from [Name] → click [Properties].
Specify the desired settings in the printer driver screen → click [OK].
Click the tabs for the [Page Setup], [Finishing], [Paper Source], and [Quality] tabs, and then specify the desired items.
The default setting for [Print Style] in the [Finishing] tab is [2-sided printing]. For details, see "1-sided and 2-sided Printing."
For information on available printing functions, see "Printing Functions" or the online help (see "Viewing the Online Help").
4.
Click [OK].
Printing begins.
Some printer models enable you to stop printing from a printer status confirmation/print cancelation display (see "Checking and Canceling Jobs from the Job Status Screen").
If a printer icon is displayed in the task tray at the bottom right of your computer monitor, you can stop printing from your computer. Double-click the printer icon → click the name of the file you want to stop printing → click [Document] → [Cancel].
» Print » Printing from a Computer (Windows) » Printing Fundamentals » Printing
08KY-1JH
