Category Top
System Configuration
Optional Equipment
Sample System Configurations
System Options
Optional Products Required for Each Function
Upright Control Panel-B1
Duplex Color Image Reader Unit-G1
Tab Feeding Attachment Kit-B1
Paper Deck Unit-A1/Paper Deck Unit-D1
USB Device Port-A2
Multimedia Reader/Writer-A2
Printer Cover-B1
Staple Finisher-P1/Booklet Finisher-P1/External 2/3 Hole Puncher-A1
Document Insertion/Folding Unit-H1/Document Insertion Unit-L1
Copy Tray-Q1
Copy Card Reader-F1
ADF Access Handle
Removable HDD Kit
Setting/Removing the Hard Disk Holder
Software
imageWARE ADVANCE Desktop
imageWARE Enterprise Management Console
imageWARE Publishing Manager
imageWARE Scan Manager DS
Workflow Composer
imageWARE Document Server|
If the machine is in the Sleep mode (the touch panel is not displayed, and only
(Energy Saver) is lit), you may be unable to open the Paper Deck Unit-A1 or Paper Deck Unit-D1. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the Paper Deck Unit-A1 or Paper Deck Unit-D1. |
The following paper sizes can be loaded into the Paper Deck Unit-A1 or Paper Deck Unit-D1:
The paper size of the Paper Deck Unit-A1 is fixed to LTR. For instructions on changing the paper size that can be loaded in the Paper Deck Unit-A1, contact your local authorized Canon dealer.
Paper Deck Unit-A1
Paper Deck Unit-D1
Release Button
Press to move the Paper Deck Unit-A1 or Paper Deck Unit-D1 away from the main unit when you want to detach either of them from the machine.
Open Button
Press to open the Paper Deck Unit-A1 or Paper Deck Unit-D1 when you need to load paper or check for a paper jam.
Paper Deck
Up to 3,500 sheets of paper (20 lb bond (80 g/m2)) can be loaded. |
4.
Paper Supply Indicator
Enables you to check the amount of paper remaining in the Paper Deck Unit-A1 or Paper Deck Unit-D1.
