Paper Deck Unit-A1 and Paper Deck Unit-D1 are optional product.
Paper can also be jammed in the feeding slot on the side of the main unit. Remove any jammed paper from the feeding slot.
CAUTION |
When reconnecting the paper deck unit to main unit, be careful not to get your fingers caught, as this may result in personal injury.
The inside lifter automatically descends to the paper loading position.
If the machine is in the Sleep mode (the touch panel is not displayed, and only
(Energy Saver) is lit), you may be unable to open the paper deck unit. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the paper deck unit. |
Look carefully, as jammed paper may be difficult to see.
CAUTION |
When closing the paper deck unit, be careful not to get your fingers caught, as this may result in personal injury.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
