OOXML Settings
You can set the color graphics and background images when creating files with Office Open XML file format.
This setting is disabled when sending via fax or I-fax.
Press [Function Settings] → [Common] → [Generate File].
Press [OOXML Settings].
4.
Specify each setting → press [OK].
Settings:
<Background Image Level>:
[Quality Priority]:
The data size is large and the background image quality is high.
[Standard]:
The data size and background image quality are in between those of [Data Size Priority] and [Quality Priority].
[Data Size Priority]:
The data size is small and the background image quality is low.
<Color Image Recognition Level>:
[High]:
Sets the highest recognition level. (The data size becomes large.)
[Standard]:
The recognition level and data size are in between those of [High] and [Do Not Recognize].
[Do Not Recognize]:
Sets a standard recognition level. (The data size becomes small.)
<Color Image Line Width Recognition>:
[On]:
Recognizes Color Image Line Width.
[Off]:
Does not recognize Color Image Line Width.
» Settings/Registration » Function Settings » Common » Generate File » OOXML Settings
08KY-08H
