Terms and Conditions
Please use the Web Access Software (hereinafter referred to as the "Software") under the terms and conditions below.
Terms and conditions for use of the Software:
You may use the Software only on the Canon product specified when acquiring a License Access Number (hereinafter referred to as the "Hardware"), and you may not use the Software on any device other than the Hardware. The Software may not be shared, installed, or used concurrently on different computers.
Other than as set forth in this Terms and Conditions section, you may not transfer, sublicense, sell, rent, lease, or lend the Software to another person or entity and you may not make copies of the Software.
You may not alter, modify, adapt, convert to another programming language, decompile, disassemble, or otherwise reverse engineer the Software in part or in full, and you shall not have another person or entity do so. You may not separate the Software from the Hardware, and you shall not have another person or entity do so.
Canon or someone designated by Canon may audit your use of the Software for compliance with these terms at any time. In this case, Canon or the party designated by Canon will give you reasonable notice of the audit.
You may permanently transfer all of your rights to another person or entity to use the Software only when you transfer the Hardware itself to them, provided you retain no copies and transfer all of the Software (including all component parts, the media and printed materials, any upgrades or anything related to the Software including, but not limited to, its instruction manual). The recipient must use the Software under the terms and conditions outlined in this Terms and Conditions section.
You may not remove or alter any trademarks, trade names, product names, logos, copyrights or other proprietary notices, legends, symbols, or labels of Canon or its licensors in the Software.
Canon or its licensors retain all rights, titles and interests, including all copyrights and intellectual property rights, in and to, the Software and all copies thereof.
You may not export or re-export, directly or indirectly, the Software in violation of any related laws, restrictions and regulations, or without all necessary approvals.
Canon or its licensors in the Software, Canon's subsidiaries and affiliates, and Canon's distributors and dealers are not responsible for maintaining or assisting you in your use of the Software and are not responsible for updates, bug-fixes, or support for the Software. If an upgrade version of the Software is provided to you, it is provided to you in exchange for the previous version. In this case, such an upgrade version is regarded as the Software and used under the terms and conditions outlined in this Terms and Conditions section. You can no longer use the previous version or transfer the rights to another person or entity.
Except when required by an applicable law, Canon or its licensors disclaim all warranties and representations, whether expressed, implied, or otherwise, including the warranties of merchantability or fitness for a particular purpose. Also, there is no warranty of non-infringement. The Software is not designed, intended, or licensed for use in hazardous environments requiring fail-safe controls, including without limitation, the design, construction, maintenance, or operation of nuclear facilities, aircraft navigation or communication systems, air traffic management or control systems, life support systems or weapons systems.
CANON INC.
» Web Access » Terms and Conditions
08KY-17J
