Two options shortcuts are displayed on the Scan and Send screen. [2-Sided Original] and [Different Size Originals] are displayed as default. These shortcuts can be changed to functions that you frequently use.
Press [Scan and Send] →
![](./images/book_images/b_in_air.jpg)
Press [Register Options Shortcuts].
Select the button to register to.
4.
Select the [Options] mode you want to assign as a shortcut → press [OK].
If you do not want to assign an option, select [Unassigned].
5.
Press [OK].
6.
Press [Close].
