Specifying Authentication Method for Rights Management Server
You can specify the authentication method for accessing a Rights Management server.
Select the authentication information used for accessing a Rights Management server.
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Set Authentication Method] → [Info. Used for Rights Mgmt. Server Auth.].
Select information used for Rights Management server authentication.
Details of each item are shown below:
[Device Settings]:
Uses the authentication information set in [Rights Management Server Settings]. (See "Setting a Rights Management Server.") Further settings are not required for every user.
[Regist. Info. for Each User]:
Uses the authentication information registered by each user of a Rights Management server. Further settings are required for each user.
4.
Press [OK].
Log in to the machine.
Press
(Main Menu) → [Scan and Send] →
→ [Register/Edit Information for Each User].
You can register user information from  on [Scan and Send] Basic Features screen, [Access Stored Files] Send screen, and [Fax/I-Fax Inbox] Send screen.
Press [Rights Management Server Auth. Information].
4.
Enter the user name and password used for Rights Management Server authentication → press [OK].
