Top » Remote UI » Restarting the Machine
08KY-1U4
The System Manager Settings enable you to restart the machine from the Remote UI.
When the machine is restarted, all the jobs currently underway are canceled. Make sure that all processing is complete before restarting the machine.
To restart the machine, it is necessary to log in as an administrator.
Click [Settings/Registration] → [Restart Device] → [Perform Restart].
Click [OK].
Restarting the machine may take some time.
After you change the network settings, restart the machine to enable the changed settings.
After restarting the machine, if the machine does not recognize its optional equipment, turn OFF the power of the optional equipment, and then turn it back ON. For more information on the power switches, see "Before You Start Using This Machine."
