You can print directly by entering the LPR command in the command prompt.
Settings specified by the command prompt or touch panel display are available for commands.
Specifies from the command prompt
You can specify LPR command settings with the P option, where each item is separated with an underscore ( _ ). The following commands are supported with this machine.
Item
Command
Paper Size
A3, A4, A5, B4, B5, LETTER, LEGAL, LEDGER (11" x 17")
Layout
SIMP (One-sided), DUPL (Two-sided/Long Edge), DUPS (Two-sided/Short
Edge)
Copies
C<Number of copies>.
Command example (with Paper Size as "A4", Layout as "DUPL", and Copies as "20"):
Input Example: lpr -S <IP Address> -P A4_DUPL_C20 <file name>
If settings have not been specified from the command prompt, settings in the touch panel display will be enabled.
Specifies from the touch panel display
Settings Menu (Common Settings) and PDF Settings Menu are available with the Direct Print function. (See "Settings Menu (Common Settings)" and "PDF Settings.")
» Print » Setting the Machine (PS/PCL/UFR II Printer) » Printing Directly Using the Command Prompt
08KY-1FU
