Setting Up a Computer for Printing/Sending a Fax
After you have completed specifying the NetWare print service settings and printer protocol settings, you are ready to set up each of the computers for printing or sending a fax.
Connecting to a NetWare Network
In order to use a NetWare network, all computers that will perform printing or sending a fax need to have NetWare client software installed. For details, see your NetWare and operating system manuals.
Printer Connection Method
Install the driver according to the following procedures indicated in the manual for each driver.
If you want to use the UFR II/PCL/PS printer driver:
See the procedure for standard installation in the Printer Driver Installation Guide.
If you want to use the fax driver:
See the procedure for standard installation in the Fax Driver Installation Guide.
When the dialog box for selecting the port appears during installation, select [Network]. From the list, select the print queue that you created in "NetWare Print Service Settings."
Depending on the machine you are using, optional equipment is required for printing from a computer or sending a fax. For information on the optional products required, see "Optional Equipment and System Requirements."
» Network » NetWare Network Setup Procedures » Setting Up a Computer for Printing/Sending a Fax
08KY-1RU
