You can set the machine to not display the screen for changing the password when a System Administrator (Administrator) logs in to the machine using the default user name and password from the touch panel display.
If you use the default password with SSO-H, security issues may arise. It is recommended that you change the password to use SSO-H.
If the password has expired, the screen for changing the password appears, regardless of this setting.
Click [Security Settings].
Select [Allow administrators to operate using default password].
Click [Update].
» MEAP » Menu for Administrators » Setting the Security for SSO-H » Allowing Administrators to Operate Using the Default Password
08KY-1Y7
