'Canon Peripheral Admins' is set in advance as the user group of the System Administrator (Administrator). The users that belong to this group can use the administrator menu as the System Administrator (Administrator). Specify the settings if you want to change the group that the System Administrator (Administrator) belongs to, or the information that is necessary for authentication when the user authentication method is changed.
Click [Configuration].
Select/enter each item in <Administrator Settings> → click [Update].
If using Active Directory Authentication:
Search Criteria:
[Exact Match] is only available.
User Attribute:
"memberOf" is only available.
Character String:
Enter the name of the group that Administrator belongs to (user group name).
If using LDAP Server Authentication:
Search Criteria:
Select [Exact Match], [Partial Match], [Start with], or [End with]. Select search criteria for comparing the attribute value acquired from the LDAP server with the user group name specified on this screen when logging in.
User Attribute:
Character String:
Do not set 'Canon Peripheral Admins' as the primary group.
» MEAP » Menu for Administrators » Setting the SSO-H » Setting the User Group to Register the Server Administrator
08KY-1Y3
