Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Menu for Administrators » Setting the SSO-H » Setting the User Authentication System
08KY-1Y1
The default setting is 'Server Authentication + Local Device Authentication'. To increase security, set the user authentication system to 'Server Authentication' or change the user name and password of Local Device Authentication for the administrator immediately after you start using SSO-H.
Click [Configuration].
Select each item in <Set User Authentication System> → click [Update].
[User Authentication System]
[Server Authentication]
Uses only Server Authentication.
[Server Authentication + Local Device Authentication]
Uses both Server Authentication and Local Device Authentication.
[Local Device Authentication]
Uses only Local Device Authentication.
[Authentication Server Type]
[Active Directory]
Uses authentication that is performed in a Windows domain environment.
[LDAP Server]
Uses authentication that is performed on an LDAP server environment.
Changes to the login service settings are enabled after the machine is restarted. After changing the settings, turn the main power of the machine OFF, wait 10 seconds, and then turn the power ON. For instructions on turning ON/OFF the machine, see "Main Power and Energy Saver Key."
If the network for Active Directory that can authenticate server is not set, do not select "Server Authentication". You will not be able to log in. If you are unable to log in, select the login service other than SSO-H, and then uninstall and re-install SSO-H. For instructions on specifying the login service settings, and uninstalling/reinstalling SSO-H, see "Managing Applications" and "Installing Applications."
In addition to the Local Device Authentication administrator, the Server Authentication administrator can also set the user authentication system.
