Before an administrator logs in to SMS, they should start the machine and follow the procedure below:
Specify the Network Settings
Specify the settings under [Network] in [Preferences] (Settings/Registration) and find out the machine's IP address. (See "Network.")
Specify the SSL Encrypted Communication Settings
SMS always uses SSL encrypted communication. If the default key for SSL is not set in advance, you cannot log in to SMS.
Enable Access to the Machine from the Web Browser
Set [Use HTTP] to 'On' in [TCP/IP Settings] in [Network] in [Preferences] (Settings/Registration). If it is not set to 'On', you cannot access the machine from the Web browser. For more information, see "Settings Common to TCP/IPv4 and TCP/IPv6."
By setting [Use HTTP] to 'On', you can open a necessary port. However, it is recommended that it is set to 'Off', if a port is not used. If you leave the port open, an unauthorized user may access the machine.
» MEAP » Before Starting SMS (Preparations)
08KY-1WH
