For information on the system requirements for using this function, see "Sending Data."
The file servers you can use differ depending on the network you are using. For information on the file servers you can use, refer to the following, according to the network you are using.
Setting Up a Computer as a File Server for a TCP/IP network
Setting Up a Computer as a File Server for an SMB/CIFS network
