You can manually print the system information when required.
The items printed for the report and a description of each item are indicated below.
Prints the version compatible with MEAP.
Prints the ID compatible with MEAP.
Prints the name of the application.
Application ID/System Application Name
Prints the system application's file name or the Application ID of a standard application.
Prints the application's version number.
Prints the status of the application.
Prints the date and time the application was installed.
Prints the name of the application vendor.
Prints the license status.
Prints the expiration date of the license.
Prints the upper license limit for each counter.
Prints the current value for each counter.
Prints the current value for each register.
Prints the maximum amount of memory that can be used by each application. The Maximum Memory Usage number is printed in kilobytes (KB).
Prints the service registered on the MEAP framework from the application. The Registered Service is printed only if there is data that corresponds to it.
The printed items are subject to change, as we are constantly improving our products.
Printing Installed Application Information
Press
![](./images/book_images/b_in_Add.jpg)
(Settings/Registration).
Press [Management Settings] → [License/Other] → [MEAP Settings].
Press [Print System Information].
4.
Press [Yes].
