Adjusting the Position and Angle of the Touch Panel Display (Upright Control Panel-B1)
You can adjust the position and angle of the Upright Control Panel-B1. Adjust the position and angle of the control panel if the touch panel display cannot be seen clearly.
This procedure is necessary only if the Upright Control Panel-B1 is attached.
Hold the control panel with both hands, and slowly adjust the position and angle, as shown below.
You can adjust the angle of the arm, as indicated below. If you exceed the adjustment range in any direction, you could break the arm that supports the control panel.
Approximately 40° Up and Down
Approximately 57° Sideways
You can adjust the angle of the control panel, as indicated below. If you exceed the adjustment range in any direction, you could break the arm that supports the control panel.
Approximately 80° Sideways
Approximately 130° Sideways Rotation
» Basic Operations » The Touch Panel Display » Adjusting the Position and Angle of the Touch Panel Display (Upright Control Panel-B1)
08KY-016
