The following system environments are necessary in order to use the scanner driver.
Operating Systems:
Windows XP (32bit) Service Pack 3 or later
Windows Vista
Windows 7
Windows 8
Windows 8.1
Windows Server 2003/R2
Windows Server 2008
Windows Server 2008 R2 (64bit)
Windows Server 2012 (64bit)
Applications:
32-bit TWAIN-compatible applications
WIA 1.0 (Windows XP) or WIA 2.0 (Windows Vista or later)-compliant applications
Computer
Any computer that runs the above systems
Hard disk space
When installing: About 100MB
When using the driver: About twice the amount of the scanned image size
Memory
Windows XP/Server 2003/Server 2003 R2/Vista/Server 2008/Server 2008 R2: Minimum 512MB
Windows 7/8 (32bit): Minimum 1GB
Windows 7/8 (64bit)/Server 2012: Minimum 2GB
A display with a resolution of at least 1024 x 768 and capable of displaying at least 256 colors.
A network host adapter capable of TCP/IP and UDP/IP communication on an Ethernet network.
When scanning large numbers of images or images containing large amounts of image data, an insufficient memory error or notable loss of scanning speed may occur. If this happens, the following procedures should prove useful.
Increase the amount of hard disk space by deleting or otherwise appropriately processing unnecessary files on the hard disk etc. to ensure sufficient hard disk space.
Rescan with reduced resolution.
Increase the amount of RAM.
Increase the amount of virtual memory to the highest possible.
Divide originals into several sets and then scan them separately.
