The driver is set to unidirectional printing mode immediately after the machine is added in [System Preferences]. If you are using a device that supports bidirectional printing, display the printer information to switch to bidirectional printing mode.
When the driver is switched to bidirectional printing mode, setting the options manually will have no effect on the driver. If you want to set the options manually, delete and add the fax again in [System Preferences], then set the options manually without displaying the printer information.
For details on how to add the fax, refer to the "Canon Fax Driver Guide" (see "Installation").
