Matching Method
[Perceptual]*, [Saturation], [Colorimetric]
This setting allows you to specify a method of printing when the "RGB Source Profile" is applied. This machine includes a color management system that provides the following color rendering styles.
Settings can be applied separately for text, graphics, and image data.
[Perceptual]
This setting produces the best results for photographic or bitmapped images.
[Saturation]
This setting is best suited for printing illustrations and diagrams used in business presentations.
[Colorimetric]
This setting provides a close match to the RGB color value of the machine's printing range.
Selecting [Normal] or [TR Normal] in the "Output Profile" and [Perceptual] in the "Matching Method" is equivalent to setting "Matching Method" to [Perceptual(Normal)] in the printer driver.
Selecting [Photo] or [TR Photo] in the "Output Profile" and [Perceptual] in the "Matching Method" is equivalent to setting "Matching Method" to [Perceptual (Photographic)] in the printer driver.
Selecting [Photo] or [TR Normal] in the 'Output Profile' and [Saturation] in the 'Matching Method' is equivalent to setting 'Matching Method' to [VIVID Photo] in the printer driver.
If [None] is selected for the 'RGB Source Profile' or 'CMYK Simulation Profile', and the machine receives a device dependent color space definition that is color processed by the host computer, a Matching Method setting is not applied.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » PS Settings » Matching Method
0JJC-1A1
