Pure Black Text
[On]*, [Off]
This setting affects the printout for black (R=G=B=0% or C=M=Y=100%/Bk=N% or C=M=Y=0%/Bk=100%) text on a page. Under most circumstances it is preferable to leave this option set to [On].
[On]
Black colors generated by applications are printed using only 100% black toner. This means that the color toner will not be misaligned since only one toner color (black) is used.
[Off]
The black text is printed using CMYK toners based on the selected Output Profile setting. For some jobs, it is preferable to turn this option [Off].
Depending on the data to be printed, 'Toner Save' may not be applied even if [On] is selected.
If [On] is selected for 'Toner Save', very light or finely detailed images may not be printed clearly.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » PDF Settings » Pure Black Text
0JJC-1C1
