CMYK Simulation Profile
[JapanColor(Canon], [US Web Ctd(Canon], [Euro Standard], [None]*, [Download Profile]
This setting allows you to specify the simulation target to print the CMYK (Cyan Magenta Yellow blacK) data.
The machine converts CMYK data into a device dependent CMYK color model based on the simulation target selected in the CMYK Simulation Profile.
[JapanColor(Canon]
This setting uses the JapanColor profile. This is for obtaining a printout closely matching the printing standard in Japan.
[US Web Ctd(Canon]
This setting uses the U.S. Web Coated profile. This is for obtaining a printout closely matching the printing standard in the USA.
[Euro Standard]
This setting uses the Euro Standard profile. This is for obtaining a printout closely matching the printing standard in Europe.
[None]
When this setting is selected, device dependent CMYK data is printed as is without applying the CMYK profile.
[Download Profile]
You can store up to 100 profiles.
You may not be able to use all the profiles that are available. If color data is printed in gray using a downloaded profile, check the downloaded profile for compatibility.
If the machine receives data with a device independent (CIE based) color space definition, it is color processed with the specified settings. Therefore 'CMYK Simulation Profile' is not applied by the machine.
When a setting other than [None] is selected, and the machine receives a device dependent color space definition that is color processed by the host computer, 'CMYK Simulation Profile' is also applied by the machine.
You can also download the profile from imageWARE Enterprise Management Console.
When [None] is selected, areas of dark color may be blotchy depending on the data.
If a profile with the name of "None" is downloaded to the machine, the profile is not applied and the [None] setting on the menu is applied.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » PDF Settings » CMYK Simulation Profile
0JJC-1C4
