Matching Method
[Text]: [Perceptual]*, [Saturation], [Colorimetric]
[Graphics]: [Perceptual]*, [Saturation], [Colorimetric]
[Image]: [Perceptual]*, [Saturation], [Colorimetric]
This setting allows you to specify a method of printing when the "RGB Source Profile" is applied. This machine includes a color management system that provides the following color rendering styles.
Settings can be applied separately for text, graphics, and image data.
[Perceptual]
This setting produces the best results for photographic or bitmapped images.
[Saturation]
This setting is best suited for printing illustrations and diagrams used in business presentations.
[Colorimetric]
This setting is only applied if 'CMS(Matching)/Gamma' is set to [CMS].
The settings for the printer driver and the touch panel display of the UFRII Printer are as follows:
Printer Driver Settings
Touch Panel Display Settings
Perceptual (Match the Monitor)
Set "Matching Method" to [Colorimetric] → set "Output Profile" to [Normal].
Perceptual (Photographic)
Set "Matching Method" to [Colorimetric] → set "Output Profile" to [Photo].
Saturation
Set "Matching Method" to [Saturation] → set "Output Profile" to [Normal].
Colorimetric (No White Point Correction)*
* Colorimetric (No White Point Correction) can only be set on Windows XP.
To activate the settings in this section, set "CMS(Matching)/Gamma" to [CMS].
To set [Colorimetric], set "Matching Method" to [Colorimetric] → set "Output Profile" to [Photo].
If you want to set "Vivid Photo" when the UFR II driver is installed, set "Matching Method" to [Saturation] → set "Output Profile" to [Photo].
» Print » Setting the Machine (PS/PCL/UFR II Printer) » UFR II Settings » Matching Method
0JJC-18A
