Setting Your Personal Folder as the Destination
A personal folder can be set for each authenticated user. You can specify your own folder as the destination.
A personal folder is enabled only if you are managing users by login service, such as SSO-H.
For information on how to specify a personal folder, see "Specifying Personal Folders."
Press [Scan and Send] → [Personal Folder].
If you are using a login service, it is necessary to log in to the machine with the appropriate procedure for the login service. To use SSO-H as the login service, see "Login Service."
If the screen for registering a personal folder is displayed after pressing [Personal Folder], you need to specify each item on the screen. For more information on each setting item, see "Specifying a File Server Using the Keyboard."
To verify/change the path of the personal folder or the authentication information, press  on the top right of the screen → [Register/Edit Info. for Each User] → [Personal Folder]
The administrator can limit the destination for file transmission to each personal folder of the general user. (See "Restricting Destination for File Transmission.")
» Scan and Send » Specifying Destinations » Setting Your Personal Folder as the Destination
0JJC-0U9
