When the Setup Guide is started and closed, the machine will restart. Before the machine is restarted, make sure that there are no jobs currently in progress.
This mode is not available if login authentication (authenticated by SSO-H or Department ID Management, or by control cards) is enabled.
(Settings/Registration).|
Procedure
Item
Setting Description
Remarks
Required Permission Level
1
<Language/Keyboard Switch>
Select the displayed language and keyboard layout.
General Users/System Managers
2
<Paper Settings>
Set the paper size for each paper drawer.
You can close the Setup Guide here. To close the Setup Guide, press [Skip].
3
<Date/Time Settings>
Set the date and time.
The Log In screen is displayed. Log in as an administrator.
System Manager
4
<Use IP Address>
Specify IPv4 and/or IPv6, and each IP address.
5
<DNS Server Address Settings>
Configure the DNS Server Address Settings, the DNS Host/Domain Name Settings, and the DNS Dynamic Update Settings.
6
<Proxy Settings>
Specify the Proxy Settings.
7
<Register Unit Telephone Number>
Enter the phone number for the machine.
8
<Register Unit Name>
Enter the name the machine will appear as on the network.
9
<Select Line Type>
Select line Type
10
<System Manager Information Settings>
Configure the System Manager Settings.
11
<Auto Adjust Gradation>
Automatically adjust the gradation, density, and color settings of the machine.
For more information on the operation, see "Configuring the Machine (Setup Guide)."
