The ACCESS MANAGEMENT SYSTEM can be used when SSO-H (Single Sign On H) is being used.
Changes are only effective after you restart the machine (the main power switch is turned Off, and then back On). For instruction on restarting (turning the main power switch Off and then On) the machine, see "Main Power and Energy Saver Key."
If [Use ACCESS MANAGEMENT SYSTEM] is set to 'On', you can not use the WSD Scan function.
