Registering a Key Pair File and Server Certificate File Installed from a Computer
It is necessary to generate and register a key pair in order to use encrypted SSL communication for IPP printing, e-mail and I-faxes, the Remote UI, MEAP functions via a Web browser, device information delivery, and confirming Department IDs and PIN, or when using the MEAP SMS.
A key pair file and server certificate file created on a computer can be installed in the machine using a Web browser (Remote UI). The procedure for registering installed files in the machine using the control panel is as follows:
Press [Management Settings] → [Device Management] → [Certificate Settings].
Press [Register Key and Certificate] → select the file to register → press [Register].
To delete an unnecessary file, select the file → press [Delete].
4.
Press [Key Name].
5.
Enter the name of the private key → press [OK].
6.
Press [Password].
7.
Enter the password → press [OK].
8.
Press [OK] → [OK] → [OK].
To confirm the key pair and server certificate you have registered, see "Editing Key Pairs and Server Certificates."
Up to six key pairs can be registered.
You can register only key pair files which use the RSA or ECDSA algorithm.
For instructions on how to install a key pair file and server certificate file, see "Installing a Certificate File."
» Security » Key Pair and Server Certificate Settings for Encrypted SSL Communication » Registering a Key Pair File and Server Certificate File Installed from a Computer
0JJC-1UH
