Enlarge/Reduce to Fit Size
[On], [Off]*
This setting enlarges or reduces the original document to match the printable area of the paper size.
[On]
The document is reduced to a page size that fits the paper size if the page size specified in the PDF file is larger than the printable area of the paper size. Conversely, the original document is enlarged to a page size that fills the paper size if the page size specified in the PDF file is smaller than the printable area of the paper size.
If you specify [Auto] in [Paper Size] using the Remote UI, this setting is not applied.
The PDF file page size is enlarged or reduced with the same ratio for both the length and width.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » PDF Settings » Enlarge/Reduce to Fit Size
0JJC-1AW
