Zoom Mode
[Off]*, [Auto]
This setting enlarges or reduces the size of an image to match the printable area of the paper size specified.
[Auto]
The size of the image is automatically enlarged or reduced to match the printable area of the specified paper size. If the size of the image is larger than the printable area, it is automatically reduced. If the size of the image is smaller than the printable area, it is automatically enlarged.
If there is blank space in the top, bottom, left, and right edges when using this setting, use the Print Position setting in combination with this setting to adjust the print position.
This setting uses the same ratio for both the length and width to enlarge or reduce the size of the image.
Even if you select [Off], the image size is automatically reduced if it is larger than the printable area of the specified paper size.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » Imaging Settings » Zoom Mode
0JJC-1AC
