Initialize
[Yes], [No]
The menu settings can be reset to the factory defaults by initializing the printer settings.
If you select Initialize, the confirmation message <Is it OK to initialize the settings?> appears. If you select [Yes], the settings are initialized. If you select [No], the settings are not initialized.
Do not turn Off the machine while the settings are being initialized, as doing so may damage the machine's memory.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Initialize
0JJC-185
