Mode Priority
[None]*, [PS], [PCL], [XPS], [PDF]
[PDF] is only applicable for the PDF Direct Print Printer or PS Printer. [XPS] is only applicable for the XPS Direct Print Printer.
This setting determines which personality should be used if a job is received without a specified command language or Direct Print data. The Mode Priority mode is used when you set [Personality] to [Auto].
None
This does not specify a preferred personality. If a job is received without a specified command language or Direct Print data, the current personality is used. The default setting is [None].
PS
This assigns priority to the PS personality.
PCL
This assigns priority to the PCL personality.
XPS
This assigns priority to the XPS mode.
PDF
This assigns priority to the PDF mode.
This mode is not available when printing in the UFR II mode.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » Mode Priority
0JJC-181
