[Auto]*, [PS], [PCL], [XPS], [Imaging], [PDF]
[PDF] is only applicable for the PDF Direct Print Printer or PS Printer. [XPS] is only applicable for the XPS Direct Print Printer.
This setting enables the machine to process data received from the host computer in the specified data format. Setting the Personality mode to [Auto] makes the machine determine the type of data received from the host on a job-by-job basis. If you are printing from applications on a computer, we recommend that you use [Auto].
If you find that the machine does not correctly switch to the appropriate personality when you [Personality] to [Auto], change the setting manually to match the data you are sending from the host computer.
This mode is not available when printing in the UFR II mode.
