2-Sided Printing
[On], [Off]*
This parameter enables you to select one-sided or two-sided printing. When the 2-Sided Printing mode is specified, the document is printed on both sides of the paper.
Two-sided printing can use either the paper drawer or the multi-purpose tray with the following sizes.
LTR, LGL, STMT, EXEC, or Custom Size (5 1/2" x 8 1/4" to 8 1/2" x 14" (139.7 mm x 210 mm to 216 mm x 355.6 mm))
Two-sided printing can use paper within the following range:
16 lb bond to 60 lb cover (60 g/m2 to 163 g/m2)
When printing on letterhead paper, or paper with a logo (such as a cover sheet), please note the following:
If the paper is fed from a paper drawer, the printing surface should be face up.
If the paper is fed from the multi-purpose tray or the paper deck, the printing surface should be face down.
» Print » Setting the Machine (PS/PCL/UFR II Printer) » Settings Menu (Common Settings) » 2-Sided Printing
0JJC-17J
