This section describes how to specify the protocol settings for the machine using the control panel. If you are configuring the settings for the first time, use the control panel of the machine.
After configuring the settings, you can change them using software other than the control panel of the machine. For more information, see
"Settings/Registration Table."
Specify the TCP/IP settings.
If you have not entered the TCP/IP settings yet, enter them now. (For more information, see
"TCP/IPv4 Settings,""TCP/IPv6 Settings," or
"Settings Common to TCP/IPv4 and TCP/IPv6.")
