NetWare Network Setup Procedures
To use a NetWare network, it is necessary to perform the following procedures.
1 NetWare Print Service Settings
Specify the NetWare print service settings. To specify the settings from the computer, use one of the following:
NWADMIN or PCONSOLE (Novell software provided with NetWare)
Canon utilities
2 Protocol Settings
Specify the protocol settings. To specify the settings, use one of the following:
The machine's control panel
The Remote UI (via a Web browser)
Canon utilities
3 Setting Up a Computer for Printing/Sending a Fax
Specify the settings of each computer you use for printing or sending a fax.
It is recommended that you consult the administrator for the network you are using when performing the settings in steps 1 and 2.
To configure settings with software other than the control panel of the machine, NWADMIN, or PCONSOLE, TCP/IPv4 protocol must be supported by your network environment (IPv6 is not supported).
» Network » NetWare Network Setup Procedures
0JJC-1HR
