Replacing the Waste Toner Container
When the waste toner container nears capacity, a message appears on the touch panel display.
In this case, you should prepare a new waste toner container.
Even if you do not replace the waste toner container immediately, you can perform printing for a while. The number of prints you can make depends on the content you print.
When the waste toner container is full, a screen with instructions on how to replace the waste toner container appears on the touch panel display. Follow the procedure described below to replace the waste toner container.
WARNING
Do not burn or throw used waste toner containers into open flames. Also, do not store waste toner containers in places exposed to open flames, as this may cause the toner to ignite, resulting in burns or a fire.
If you accidentally spill or scatter toner, carefully wipe up the loose toner with a damp, soft cloth and avoid inhaling any toner dust. Do not use a vacuum cleaner that is not equipped with safety measures to prevent dust explosions to clean up loose toner. Doing so may cause damage to the vacuum cleaner or result in a dust explosion due to static discharge.
CAUTION
If toner is ingested, consult a physician immediately.
If toner gets onto your hands or clothing, wash it off immediately with cold water. Washing it off with warm water will set the toner, and make it impossible to remove the toner stains.
Your local authorized Canon dealer will dispose of used waste toner containers.
Used toner cannot be reused. Do not mix new and used toner together.
Use only waste toner containers intended for use with this machine.
Do not replace the waste toner container before the message prompting you to replace it appears on the touch panel display.
Complete instructions on how to replace the waste toner container can be accessed by pressing [Previous] or [Next] on the touch panel display.
If the waste toner container must be replaced during a print job, the remaining prints are made after the new waste toner container is installed.
Remove the waste toner container.
1. Open the front cover of the main unit.
2. Pull out the waste toner container.
CAUTION
When removing the waste toner container, do not tilt it. If you tilt the waste toner container, toner will spill out.
Prepare a new waste toner container, and store the removed waste toner container.
1. Take the new waste toner container out of the box.
2. Insert the removed waste toner container into a bag, close and tie the bag so that the toner does not spill out, and then put the bag in a box.
Use the bag in the box for the new waste toner container.
Place the removed waste toner container on a level surface. If the waste toner container is tilted too far, toner may spill out.
Insert the new waste toner container into the main unit.
1. Align the mark on the waste toner container and the mark on the slot of the main unit, and insert the waste toner container.
2. Close the front cover of the main unit.
CAUTION
When closing the front cover of the main unit, be careful not to get your fingers caught, as this may result in personal injury.
» Maintenance » Replacement Parts » Replacing the Waste Toner Container
0JJC-0EW
