Overview of Login Services
A login service is a service for authenticating users of the machine. User authentication is performed in the following two cases:
Performing user authentication by displaying a login screen on the touch panel display
Performing user authentication by displaying a login page when accessing the machine via a Web browser
The login services included with the machine by default are Default Authentication (Department ID Management) and SSO-H (Single Sign-On H). This category explains these two login services.
Default Authentication (Department ID Management) is set to a usable state as the default. For instructions on using SSO-H, see "Login Service Selection."
You cannot use the control card reader with Server Authentication or with Server Authentication + Local Device Authentication.
You can use the functions of the machine, as well as MEAP applications if user authentication is performed once.
» MEAP » Overview of Login Services
0JJC-1KW
