Forwarding Received Faxes
Only one forwarding condition can be set for each sender. By setting forwarding conditions for multiple senders, faxes from different senders can be forwarded to and stored in separate computers.
You can set a maximum of 1,000 forwarding conditions with your imageRUNNER ADVANCE machine.
To minimize errors when forwarding documents, it is important to accurately set the fax number.
Example:
To set the machine to forward faxes received from Company A to Person X's computer, Company B to Person Y's computer, and Company C to Person Z's computer, specify the following three forwarding conditions.
Fax Number: [Equals]: registered number for Company A's fax; Forwarding Destination: Person X's computer. Fax Number: [Equals]: registered number for Company B's fax; Forwarding Destination: Person Y's computer. Fax Number: [Equals]: registered number for Company C's fax; Forwarding Destination: Person Z's computer.
Set the above three forwarding conditions.
Example:
To forward all received faxes sent from within New York City, specify the following forwarding condition.
Fax Number: [Begins with]: 212
Example:
To forward all received faxes, specify the following forwarding condition.
Fax Number: [Disregarded]
Example:
To set the machine to forward faxes received from Company A to Person X's computer, Company B to Person Y's computer, and all other faxes to the General Affairs Division computer to view/sort, specify the following forwarding conditions.
Fax Number: [Equals]: registered number for Company A's fax; Forwarding Destination: Person X's computer. Fax Number: [Equals]: registered number for Company B's fax; Forwarding Destination: Person Y's computer. Forward w/o Conditions: General Affairs Division computer
Use Forward w/o Conditions to set a forwarding destination for received faxes that do not match any specified forwarding conditions. This mode enables you to set the file name, select the file format, print when forwarding, and receive notification of forwarding completion.
[Disregarded] differs from Forward w/o Conditions in that all received faxes are forwarded, regardless of whether the faxes match any specified forwarding conditions. This means that if you set [Disregarded], faxes that match a forwarding condition are forwarded to two destinations.
Benefits of Forward w/o Conditions
Enables uniform management of faxes that cannot be forwarded to the addressee.
Extracts faxes without a specific addressee. This is particularly useful for junk faxes which can be received and viewed without printing, enabling you to save on machine running costs such as paper, toner, and maintenance.
Setting Forward w/o Conditions
Essentially, the settings are the same as when registering a forwarding condition. However, you do not set a condition name, fax number, or forwarding time.
You can perform this procedure using the touch panel display or the Remote UI.
The screens may differ, depending on the model of the machine and on attached optional products.
Using the Touch Panel Display
Press
(Settings/Registration) → [Function Settings] → [Receive/Forward] → [Common Settings] → [Forwarding Settings] → [Other Operations] → [Forward w/o Conditions].
Specify the receive method, forwarding destination, file name, file format, and other settings → press [OK].
Forward w/o Conditions is displayed on the forwarding settings screen. Select Forward w/o Conditions → press [Validate/Invalidate] and set it to 'On'.
These settings can also be specified from the Remote UI.
Access the Remote UI → click [Settings/Registration] → [Receive/Forward] → [Forwarding Settings].
Click [Forwarding without Conditions] → specify the receive method, forwarding destination, forwarding done notice, and other settings.
[Enable This Forwarding Condition] is equivalent to the [Validate/Invalidate] button in the forwarding settings screen on your imageRUNNER ADVANCE machine.
