IPSec Policy List
You can manually print the list of IPSec Policies whenever necessary.
The items printed for the report and a description of each item are indicated below.
Policy Name
Prints the name of the registered IPSec Policies.
Selector Settings
Prints the items indicated below.
Local Address: All IP Addresses, IPv4 Address, IPv6 Address, IPv4 Manual Settings, IPv6 Manual Settings
Remote Address: All IP Addresses, All IPv4 Addresses, All IPv6 Addresses, IPv4 Manual Settings, IPv6 Manual Settings
IPv4 Manual Settings or IPv6 Manual Settings: Prints the IP address.
Port:
Specify by Port Number:
Local Port: All ports, Specify Port
Remote Port: All ports, Specify Port
Specify by Service Name:
List: On, Off
Prints Service Name.
IKE Settings
IKE Mode: Main, Aggressive
Authentication Method: Pre-shared Key Method, Digital Sig. Method
Pre-shared Key Method: Name of Shared Key
Digital Sig. Method: Name of Default Key
Auth./Encryption Algorithm: Auto, Manual Settings
Manual Settings:
Authentication: SHA1, SHA2
Encryption: 3DES-CBC, AES-CBC
DH Group: Group1 (768), Group2 (1024), Group14 (2048), ECDH-P256, ECDH-P384
IPSec Network Settings
Validity
Time: On, Off
Size: On, Off (If On is set, prints the specified value.)
Connect. Mode: Transport
PFS: On, Off
Manual Settings: ESP, ESP (AES-GCM), AH (SHA1)
If ESP is set:
ESP Auth.: SHA1, NULL
ESP Encryption: 3DES-CBC, AES-CBC, NULL
Only an administrator can output the IPSec Policy List. (See "Administrator Settings.")
Printing IPSec Policy List
Press [Preferences] → [Network] → [TCP/IP Settings].
Press [IPSec Settings] → [Print List].
A list of the IPSec policies is printed and you can confirm their priorities.
» Basic Operations » Printing Reports » IPSec Policy List
0JJC-032
