A Fax RX Report can be printed automatically after documents are received, and you can also set the machine to print a Fax RX Report only when a reception error occurs.
The items printed for the report and a description of each item are indicated below.
The four digit number, that is automatically assigned when the document is accepted for receiving, is printed.
The fax number of the sender is printed, up to the first 47 digits.
A subaddress is printed, if specified. The password is not printed to maintain security.
The DESTINATION ID of the sender is printed.
The date and time (in 24-hour notation) at which the document started to be received are printed.
The time taken (in minutes and seconds) to receive the document from start to finish is printed.
The number of pages that were received is printed.
Prints "OK" or "NG."
If a receive job is canceled, <STOP> is printed.
OK:
Reception was completed successfully.
NG:
Reception failed. The error code is also printed next to "NG."
Printing the Fax RX Report
Press
(Settings/Registration).
Press [Function Settings] → [Receive/Forward] → [Fax Settings].
Press [Fax RX Report].
4.
Press [For Error Only] or [On].
Press [Off] if you do not want to print the report.
5.
Press [OK].
