If a sequential broadcast transmission is performed when [Fax TX Report] is set to On, a Fax Multi TX Report is automatically printed.
(See "FAX TX REPORT/FAX ERROR TX REPORT.")
You can also print a Fax Multi TX Report with an image of the sent original attached to it.
The items printed for the report and a description of each item are indicated below.
The four digit number, that is automatically assigned when the document is accepted for sending, is printed.
If Department ID Management is set, the Department ID is printed.
The number of pages that were sent is printed.
If a transmission is incomplete, the fax number and the name of the destination are printed.
The fax number and the name of the destination of a completed transmission are printed.
If a transmission error occurs, the fax number and the name of the destination are printed.
If an image is not attached, <TX IMAGE SET NOT TO DISPLAY> appears below the title.
If it is unclear whether the document was successfully received at the destination, "---" is printed.
