If an image is not attached, <TX IMAGE SET NOT TO DISPLAY> appears below the title.
If there is no destination for TX INCOMPLETE, TRANSACTION OK, or ERROR, "---" is printed.
If a field exceeds its display capacity, only those characters that fit in the display are printed.
A list of fax, e-mail, I-fax, and file server transmissions is printed on the TX Report. However, even if <Report with TX Image> is set to 'On', if the document was sent using the Encrypted PDF mode, the original will not be displayed.
Send jobs originating from the fax driver are omitted from this report.
(Settings/Registration).
Even if <Report with TX Image> is set to 'On', the contents of the sent document are not printed on the report if the document was sent using the Encrypted PDF mode.
The results of fax transmissions are printed. In addition, a Fax TX Report is printed with the TX Report, if [Fax TX Report] in [Function Settings] (Settings/Registration) is set to 'For Error Only' or 'On'. (See "FAX TX REPORT/FAX ERROR TX REPORT.")
