![](./images/book_images/b_in_Start.jpg)
Thin originals may become creased, if used in a high temperature or high humidity environment.
If you scan long originals, whose width is 17" to 24 7/8" (432 mm to 630 mm), support originals by hand when feeding and outputting paper.
![]() Do not place the following types of originals into the feeder:
Originals with tears, five or more binding holes, or cutouts
Severely curled originals or originals with sharp folds
Wrinkled originals
Stapled originals or originals with paper clips
Tabbed originals
Originals with adhesive tape or glue
Originals that are taped together
Carbon backed paper or other originals which may not feed smoothly
Transparencies and other highly transparent originals
Always smooth out any folds in your originals before placing them into the feeder.
Do not insert your hands in the gap in the original supply tray, as doing so may cause injury.
Do not drop clips or other objects into the gap in the original supply tray.
Do not add or remove originals while they are being scanned.
When scanning is complete, remove the originals from the original output area to avoid paper jams.
Do not place items in the original output area, as doing so may cause damage to your originals.
The scanned originals are output to the original output area in the order they are fed into the feeder.
If you are scanning LTR and LGL originals loaded in the feeder at the same time, select [Auto (LTR/LGL)] on the Select Paper screen.
Limit repeated feeding to a maximum of 30 times (this number varies, depending on the type and quality of the original). If the same original is fed through the feeder repeatedly, the original may fold or become creased, and make feeding impossible.
If the feed rollers are dirty from scanning originals written in pencil, perform the feeder cleaning procedure. (See "Scanned Originals Become Dirty (Manual Feeder Cleaning).")
