Registering Shortcut Keys
You can register settings in the shortcut keys displayed on the Fax screen. You can register up to four desired buttons from [Options].
This feature is useful when you want to register frequently used functions.
Press [Function Settings] → [Send] → [Fax Settings].
Press [Register Options Shortcuts].
4.
Select the shortcut button → select the setting to be registered in the button.
To cancel the setting currently registered in a button, select [Unassigned].
5.
Press [OK] → [OK].
Example: The registered shortcut buttons are displayed as shown below.
» Settings/Registration » Function Settings » Send » Specifying the Fax Settings » Registering Shortcut Keys
0JJC-09S
