Inserting a Job Separation Sheet between Copy Sets
If you are using the Collate, Offset Collate, or Staple mode, you can insert blank pages from a selected paper drawer to separate a specified number of copies.
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Job Separator Between Copies].
4.
Press [On] → [OK].
Select [Off] if you do not want to insert a job separation sheet between copy sets.
To change the paper source for the job separation sheets, press [Change] → select the paper source → press [OK].
To set the number of copy sets to insert a job separation sheet, enter the number using  -  (numeric keys).
If you are using the Group (Same Pages) mode, you cannot insert job separation sheets between copy sets.
» Settings/Registration » Function Settings » Common » Paper Output Settings » Inserting a Job Separation Sheet between Copy Sets
0JJC-075
