Displaying the Current Department ID/User Name
If you are using a login service, you can display the Department ID or user name that is currently logged in to the machine on the bottom line of the touch panel display.
The item displayed for each login service is shown below:
Login Service
Default Authentication
Department ID
SSO-H (Single Sign-On H)
User Name
Press [Preferences] → [Display Settings] → [ID/User Name Display On/Off].
Press [On] → [OK].
Press [Off] if you do not want to display the Department ID/user name.
If you set [ID/User Name Display On/Off] to 'On', and you are not using a login service, the Department ID/user name does not appear.
» Settings/Registration » Preferences » Display Settings » Displaying the Current Department ID/User Name
0JJC-05H
