      0KCF-0J7
      Managing the Machine Remotely
      You can use the Remote UI from a Web browser installed on your mobile device. This allows you to check the machine's status and specify the machine's settings from your mobile device. Note that the Remote UI screen may not be displayed properly for some devices and environments.
      Starting Remote UI with a Mobile Device
      Enter the IP address of the machine into the Web browser and start the Remote UI. Check the IP address set to the machine in advance (Viewing Network Settings). If you have any questions, ask your Network Administrator.
      1
      Start the Web browser on your mobile device.
      2
      Enter "http://(the IP address of the machine)/" in the address field.
      If you want to use an IPv6 address, enclose the IPv6 address with brackets (example: http://[fe80::2e9e:fcff:fe4e:dbce]/).
