To perform the following procedure, log on to your computer with an administrator account.
You may be unable to install drivers over the network depending on the operating system and the bit architecture (32-bit or 64-bit) of the print server and client computers.
When implementing a print server in a domain environment, consult your Network Administrator.
Using Department ID Management with a print server
Canon Driver Information Assist Service must be added during the printer driver installation. For more information, see the Printer Driver Installation Guide included with the printer driver.
1
Click [Additional Drivers].
2
Select the check box for the bit architecture that other computers are running, and click [OK].
![]() Select additional drivers from the following, according to the operating system of the print server.
NOTE:
If you do not know whether your Windows Vista/7/8/8.1/Server 2008/Server 2012 is a 32-bit or 64-bit operating system, see Checking the Bit Architecture.
3
Click [Browse] to specify the folder that contains the printer drivers, and then click [OK].
If the print server runs a 32-bit operating system, select [DRIVERS]
[XXXXXX]* [32bit] [Driver] folders that are saved in the computer.If the print server runs a 64-bit operating system, select [DRIVERS]
[XXXXXX]* [x64] [Driver] folders that are saved in the computer.* For [XXXXXX], select your desired language.
4
Follow the on-screen instructions to install the drivers.
