This section mainly describes how to load preprinted paper with the proper facing. For a description of the general procedure for loading paper in the paper drawer or multi-purpose tray, see Loading Paper in the Paper Drawer or Loading Paper in the Multi-Purpose Tray.
Making 1-sided printouts|
Paper Drawer
Load the paper with the logo side face up.
Multi-Purpose Tray
Load the paper with the logo side face down.
Making 2-sided printouts|
Paper Drawer
Load the paper with the front logo side* face down.
Multi-Purpose Tray
Load the paper with the front logo side* face up.
* The front logo side is the side on which the first page of the document is printed.
The <Switch Paper Feed Method> setting
When you print on preprinted paper, you need to change the facing of the paper to load each time you perform 1-sided and 2-sided printing. However, if <Switch Paper Feed Method> is set to <Print Side Priority>, the facing that you use for loading preprinted paper for 2-sided printing can also be used for 1-sided printing, enabling you to eliminate the need to change the facings each time you print. This setting is especially useful if you frequently perform both 1-sided and 2-sided printing. Switch Paper Feed Method
